Brief Description: Wing Tip Nav, Strobe, and Landing Light Assemblies
I assembled the Whelan Light Assemblies and then mounted them in the wing tip. I didn't like how the metal fit on the wing tip so I fabricated my own. Next I mounted the nutplates. Mounting the nutplates onto fiberglass takes a new skill set. I had everything mounted until the last screw in the lower right, which broke off in the nut plate. Then it was a matter of disassembling everything and drilling out the old nutplate. I had to install a larger nutplate because I didn't have the same size spare...so that's why the screw is bigger then the rest. Next I cut the plexiglass lens cover in half using my metal snips. Then I painstakingly drew the pattern on the plexiglass.
Fabricated Light Assemblies
Landing & Taxi lights; Nav & Strobe Lights Mounted
