Brief Description: Installed the right wing aileron and scarfed skin
This is the jig I used to center/neutralize the aileron. It's just two bolts installed into the tooling holes and a pair of lines drawn outside the bolts to show where the neutral point of the airlron is. I also adjusted the push pull rod using the centering jig Vans provided. I also scarfed the bottom side of the skin where it over laps. I used an orbital sander to scarf the metal. It produced a very even scarfing.
