Brief Description: Finish installation of leading edge landing light
There are several steps involved in the installation. You have to drill and rivit nutplates to hold the mounting brackets, then prepare the bracket. Next you install the bracket inside the wing and cut the plexiglass to fit. A bandsaw is the only way to do this!
Light mounting bracket prepared for installation into the wing
Marked the plexiglass which had to be cut to size
Covered the plexiglass with masking tape and cut on the marked lines
