Marlins Web Site
Date:  11-3-2007
Number of Hours:  3.50
Manual Reference:  Sec 7; Dwg 15A
Brief Description:  Installed Leading Edge Landing Light; Right Wing
After cutting out and marking the template onto the wing, I drilled access holes for a jig saw and also drilled the screw holes. (On the left wing I waited to drill the screw holes until after the cutout was made and I introduced a slight error because the metal would bend and cause a minor screw misalignment.) Next I used a jig saw to drill the hole, slightly undersized. I used a file and a scotchbrite wheel to smooth out the final cut.
Template Cutout Mounted on Wing
Rough Cutout marked with access holes and screw holes drilled
Hole cutout, filed, and sanded
