Brief Description: Dimpled the left wing lower skin and scarfed the e
I dimpled the left wing lower skin and scarfed the edge where it overlaps with the lower inboard skin. I also prepared the plastic for riveting by burning with a heat gun (I haven't removed it yet but will when I finally rivet the skin). I also started tp pull the wires for my Grand Rapids Technologies Magnetometer. I couldn't get the D-Sub pin extractor I purchased from radio shack to work properly so I could disassemble the wirees from the AHRS 26 pin plug. I'm going to take the wiring harness to my computer network guys to see if they can get the pins removed so I can pull the wires. If they don't have the correct pin extraction tool I'll go out to the avionics repair shop at our local FBO. Tomorrow night I hope to pull all the wires for the leading edge lights, wing tip lights and strobes, heated pitot, and GRT magnetometer.
Scarfed the underside of the skin where it overlaps onto the inboard skin
