Brief Description: Fabricate, install, and seal fuel level senders
I fabricated the the bent wire floats for both the right and left wing fuel level capitance sending units then installed the fittings and sending units. I also rivited the fitting flange to the access plate, then sealed both units with Pro-Seal. What a mess!...I painted over the whole thing so no one can see the Pro-Seal I got all over the access plate.
