Brief Description: Install Flap Hinge and Left Flap
Tonight I aligned the flap with the aileron (1/4" gap between the two and in the neutral aileron position, aligned the trailing edges with a level). Next I drilled and clecoed the flap "piano" hinge and cut three eyelets from the center to insert two pins. I then rechecked alignment and rivited the flap hinge to the training edge of the lower wing and flap brace after dimpling and deburring the skin and flap brace. I also put a small offset bend on the trailing edge of the upper wing skin because the skin was binding slightly on the flap.
