Marlins Web Site
Date:  2-26-2007
Number of Hours:  23.50
Manual Reference:  Sec 6, DWG 3
Brief Description:  Riveting the Horizontal Stabilizer Skin (right & l
From Feb 23 - Feb 26 2007, I completed steps 43 - 62 in the manual. This included priming all the parts, riveting the hinge brackets onto the spar. I drilled and matched all the holes for the HS-404/HS-405 rib attach points, tapered the ends of the 714s and 715; bent the radius on the flanges etc. It makes a huge difference where you start riviting. Follow the instructions very carefully, or you will get "oil-cannning"> I ended replacing some riviets and starting over twice to get the skin stretched properly, even though all the holes lined up. By the time you get the 1/2 of the assembly finished it becomes somewhat unweildly because of the size of the assembly.
These pictures were taken as I riveted the top skin on both sides. I riveted the internal rib and spar assembly to the bottom skin on both the right and left sides of the horizontal stabilizer.
Horizontal Stab reinforcement bars and bearings installed
Riveting the top skin on the horizontal stab
Pic of the entire assembly
