Marlins Web Site
RV-7A
Sec6; DWG3
Front Spar Assembly of the Horizontal Stabilizer (
Image 1 show steps 14-20--HS-710 and HS-714 were clamped in wooden blocks andbent to an angle of 6 degrees.
Image 2 shows steps 22-23-- HS-404 and 405 were marked as per the drawings, the tabs were drilled.
Image 3 shows step 23--HS-404 and 405 (forward root ribs) tabs were trimmed and were filed round and deburred as per DWG 3
Tapered and bent HS 710 & 714 spar channels
Tabs marked on both forward root ribs
Tabs were cut and rounded to fit between the HS 714 and 710 spar channels
RV-7A Home
5769
Cockpit Upholstery
Constant Speed Prop
Cowling
Electrical System
86
1085
672
Engine Air-Baffles
362
Hangar
Hanger
Instrument Panel
IO360-M!B Engine
Ops Manuals
Pitot-Static System
Quickbuild fuselage
Shop, Supplies, and
Sliding Canopy
Wheel Pants/Fairings
Wheels
Wheels & Brakes
Windshield/Roll Bar
Workshop & Tools
