I purchased this lock some time ago and debated whether I wanted to use it. It consists of a phenolic block that slides on the glide rail and a push-button lock that engages small pins at the bottom; inside the fuselage. I don’t like the permanent hole in the glide rail but can install a small, threaded plug when not in use.
