Marlins Web Site
Date:  4-3-2019
Number of Hours:  9.00
Manual Reference:  Ch 9 DWG 41;43 D-
Brief Description:  Fitting the Sliding Frame to the Canopy Bubble
I intentionally cut the front split for the sliding canopy about ¼ inch too big in case I needed to adjust the front frame slightly or I made an error in the cutting process. Once I made the cut, I was able to redraw a 1/16” line for frame overlap and used a belt sander to perfectly sand-down the front plexiglass edge to match the required overlap. Next, I had to remove the plexiglass canopy from the frame to back-drill the C-653 Cover Strip. I also made the side-cuts so they are 1/8” above the frame side-bows, sanding and beveling the plexiglass edges to prevent stress fractures. I also ground-down the front edges of the roller assemblies so the flange wouldn’t ding-up the roll-over bar every time I close the canopy. Additionally, I permanently mounted the roller-tracks to the fuselage and trimmed off the portion of the tracks that extended over the side fuselage so the side skirts can be mounted without interference from the tracks.
Front Edge 1/6
Front Edge 1/6" Overlap
C-653 Cover Strip Mounted
Gaps 1'8
Gaps 1'8" Clearance for Skirts
