Marlins Web Site
Date:  12-5-2018
Number of Hours:  4.00
Manual Reference:  DWG OP-27 & 32
Brief Description:  Firewall Forward Prior to Closing Front Deck (cont
Prior to closing the front deck, I also needed to install some nutplates and clamps used to secure the oil pressure hose and a breather tube so I installed the nutplates, Oil Pressure Line and Fuel Pressure Lines onto the transducer manifold. I also ‘temporarily installed” the access panel just in case I have to get access under the deck for some unknown reason. This will later get pop rivets so it won’t be a big deal to secure it in place even after the engine is mounted. Now I am finally ready to install the sliding canopy.
DWG OP-27
DWG OP-27
Installing nutplates 3 locations
Oil pressure line secure
