After the nutplates were installed and all screw-holes were drilled for ‘dimpling’, it was time to size the pre-molded fiberglass fairing and cut off any excess fiberglass. To do this I made some paper templates for the sides of vertical stabilizer where the fiberglass drops down over the elevator horns. Then I made several cuts on the fiberglass to clear the horns and to fit around the leading edge of the horizontal stabilizer. I also cut out the access hole covers to fit into the recesses.
