Brief Description: Drilled Access Holes in FWD TOP Skin
I temporarily installed the Forward Top Skin that covers the dash-panel to determine where to drill access holes for the Vertical Card Compass Light, the WxWORX XM/WX Receiver Antenna, and the GRT RAIM GPS Antenna (both of these antennas have a small profile and will attach to the panel-cover with Velcro. I inserted rubber and plastic grommets in the holes so I can complete the wiring when I permanently rivet the Forward Top Skin. Next, I removed the GRT EFIS/EIS Failure warning light and installed a 5-AMP Push-Breaker in the hole I previously used for the failure warning light. Next, I moved the warning light to a position between the GRT EFIS and the GRT EIS.
