Brief Description: Installed UNISON Slick LASAR Low Voltage Control H
Today I installed the UNISON Slick LASAR Low Voltage Control Harness +12V Power (Red Wire) to a 10 AMP circuit breaker on the P2 Main Dropdown panel; the -12V Ground (Black Wire) to the Aircraft Ground Buss; and the UNISON Slick LASAR Low Voltage Control Harness Tachometer lead (Brown Wire) to the GRT EIS Connector A Pin #12 Tachometer- Input lead. I still need to install the 10-Pin Sensor Magneto Harness, the 8-Pin Non-sensor Magneto Harness, and the Purple and White harness wires to a CHT Probe.
