Brief Description: Oil Pressure and Fuel Pressure Sending Units
Today I built a mounting bracket and completed the final wiring for the Oil Pressure Sending Unit and the Fuel Pressure Sending Unit. I mounted the completed assembly on the firewall in the only remaining chunk of real estate left where I will still have access to the sending units if I need to replace them. I still have to check out/test all the wiring, but this finally completes the wiring to all the instruments, power, lights and switches. I’m extremely glad this is finally done. I’ve been working on this off-and-on for the last three years!
