Marlins Web Site
Date:  6-19-2017
Number of Hours:  18.00
Manual Reference:  GRT EIS
Brief Description:  Began wiring the GRT EIS
I began the final connections for the Grand Rapids Technology (GRT) Engine Information System (EIS). I tapped into the pitot and static lines and made connections to the EIS computer. Next, I mounted the Manifold Pressure Sensor Module on the firewall and ran a vacuum line through the firewall which will later be connected to the Intake Manifold Primer Port after I get the engine installed. I also provided power to the module and connected the sensor wires to the EIS. I also installed a GRT EFIS/EIS warning Light which will flash whenever there is a problem with the engine or EFIS. The light will flash and I have to manually go to the warning screen on the EFIS to acknowledge the issue and take whatever action is necessary to correct or mitigate the problem. This is a nice two step feature and the warning light will help to insure I notice there is some sort of problem I need to deal with…hopefully the lights will never flash, but it’s nice to know there are both visual and aural warnings when something isn’t right.
Manifold Pressure Module
Vacuum Line Outside Firewall
GRT EFIS/EIS Warning Light
