Brief Description: Completed all NavWorx ADS60-EXP wiring
Today I completed all NAVWORX ADS600-EXP electrical and signal connections:
•GARMIN GNS 430W, and GTX 327 Transponder RS-232 Altitude Encoder IN to the GRT HX Altitude Encoder OUT.
•GRT HX display (RS-232 ADSB Signals and Signal Ground) to display all weather and traffic to the GRT and Bluetooth connections to show weather and traffic on my iPad Mini
•Power connections to the Composite Design LSP1 Power Panel and Breakers
•Ground connections to the Aircraft Ground Bus
•UAT Antenna to pick up ADSB signals from aircraft (both bands) and ground-based transmitter/receivers
•GPS antenna as a back-up to the GARMIN GNS 430W and the GTX 327 Mode C Transponder
