Marlins Web Site
Date:  2-10-2015
Number of Hours:  8.50
Manual Reference:  Sect 8 - Fuselage
Brief Description:  Installing the Whisperflow SV Ventilators
The Whisperflo SV ventilators use the same cat-tube adapter as the VAN's ventilators and I used RTV and clamps to secure the CAT tubing. The problem was my location for the ventilators...the F-793-L&R vent brackets that all this gets attached to were so tightly crammed behind the CAT tubing, clamps and adapters, it took me 6 1/2 hours to get the 8 screws, washers, and nuts installed. In addition, the great idea I had to use RTV versus safety wire made a very gooey and difficult task of trying to get washers and nuts on screws you couldn't see or feel...What an exercise in TOTAL FRUSTRATION!!
Now that it's all done, it looks great and will be very convenient; but if I ever build another airplane this is NOT going to be where I mount the ventilators!
Left Whisperflo SV Ventilator (closed position)
Right Whisperflow SV Ventilator (open position)
My grand daughter's expression says it all!!!
