Brief Description: Installed the pitot-static system
Image1 shows the SD-42 BSLF blind rivet installed on the aft fuselage side-skin located at a neutral presurre point on the fuselage.
Image 2 shows the connections to the static port on the right side of the aircraft and the tubing going forward to the instrument panel.
Image 3 shows the connections to the static port on the left side of the aircraft and the tubing vertically connecting to the static port on the right side via a brass tee and horizontally and down connecting to the GRT AHRS.
