Brief Description: More on Magnetometer (remote compasses) install
After running new shielded wires to the strobes and re-installing all the wiring in plastic conduits; I replaced all the clamps and screws with non-ferrous clamps and brass screws, bolts, and washers. Since this is the 3rd time I've done this at least I didn't have to drill new holes for all the fittings AND I actually made some improvements to the routing to make it easier for inspections and maintenance. I re-tested the GRT Magnetometer with the strobes firing AND IT WORKS AS ADVERTISED!!! Tomorrow I'll build the mounting bracket for the Dynon remote compass.
