Marlins Web Site
Date:  2-6-2014
Number of Hours:  35.00
Manual Reference:  Section 8 - Wings
Brief Description:  Installing the wing tip spars and nut bolts
The next very time consuming task was to install the spars into the fiberglass wing tips and then install the 36 nutplates per wing so I can use screws to attach the wing tips (for removal to change lights and do maintenance). I also reinforced the fiberglass under the nutplates closest to the spars thinking there may be some vibration in this area that is not attached to the wing.
Installed spar after priming
Wing tip nutplates installed
