MIKE'S WEB SITE
Date:  12-28-2013
Number of Hours:  3.00
Brief Description:  Fuel line for left tank to selector valve
First line didn't work. Start over. Second line didn't work. Luckily I was able to salvage the first one and it actually worked out great. I was not happy to find out that the QB guys made the center support bracket slightly different than the right side. The holes for the bushings are closer to the spar which meant the fuel line needed a slight joggle. Only a cosmetic issue which will never be seen once the coverplates go on.
I also primed the wing root fairings.
