Matt, Mark, and Bruce helped with first start. Cycled the prop with starter to circulate oil. Bottom plugs were removed. Had a hard time getting the boost pump to prime. It was filled with preservative oil. Flushed fuel system by removing fuel line from firewall. Pump some. Reconnect and remove fuel injector lines and pump. Reconnect. Had a hard time getting it started. It finally went and Bruce realized it was running way too rich. Pulled mixture and it smoothed out. Ran nicely. Cycled prop. It kicked in on the third time. It needed to fill with oil. Shut down. Inspected. Bruce adjusted fuel servo 10 clicks leaner. Started again and it idled much smoother. FYI Bruce Limbach is an IA A/P. Mag check was fine. Oil and fuel pressure was fine. Brakes held fine. Alternator was charging. Hobbs .1 Oil level 6 quarts.
