Brief Description: Planning for the Cabin Speaker and AOA Alarms
Spent the day double checking the wiring considerations for the Cabin Speaker and the AOA Alarms. Used alligator clips to setup the connections and map them out. Using a 10K Ohm variable resistor, I'm able to adjust the volume of the AOA Alarms from the Dynons (as depicted in their Installation Guide). Purchased a 4" speaker from Radio Shack. Found that the speaker needs to be at least 52" from the Magnetic Compass to avoid interference. Decided to mount the speaker in the baggage area right-side access panel. Photos tomorrow.
