Brief Description: Coolant Temp Sensor and Digital clock
Have found that the Coolant Temperature sensor has been irratic. Contacted Eggenfellner and Gary N. indicated that the radiators are mounted with non-conductive adhesive and it's not un-common to have to add a ground wire to the outside of the sensor. As usual, he was right. I fashioned a .032 brass washer with a 1/4" faston tab (for the ground wire) and with the proper amount of washers, it's secured very tightly and provides the needed ground. Then, I started work on wiring the Davtron digital clock. Most of the wiring was completed before having to call it quits for the day.
