After dealing with the Map Box modification, I was finally able to get back on track by mounting the Primary Power buss, the Endurance buss, the Dimmer heat sink and the Avionics ground buss.
Left to right: Endurance power buss, Dimmer heat sink, Avionics ground buss
Primary power buss. Note it's mounted just below the area of the canopy frame
