Trial fit of the F-704 Center Section to understand how it's oriented and goes together. As the manual indicates, it's a massive assembly which is the heart of the fuselage. The gold anodized parts are beautiful.. I cut some 1 7/16 inch spacer blocks from wood to use for shims during assembly/dis-assembly. These blocks are the same diameter as the Wing spar. Pictures will come a bit later.
