Michael and Gayle's RV-7A
Date:  2-17-2007
Number of Hours:  2.50
Manual Reference:  8-18
Brief Description:  Fitting the Vertical Stabilizer
Began the day by removing the VS and trimming the VS-702 from spar as required. Re-clamped the VS and adjusted until is was centered vertically. I took measurements from the tip of the VS to both tips of the HS. Once everything was lined up, I drilled the bottom of the VS to the F-712 bulkhead.
