Started assembly today. Spent quite alot of time preparing the HS-609 rear spar reinforcement bars -- better than 5 hours in those alone with shaping, and sanding down to velvet smooth with 400 grit paper. Need to prime the HS-411, but it's such a small part I hate to mix up a batch of primer just for that. Need to look into finding some spray can primer that will work. I will have a chance to discuss this with the local EAA Chapter folks later on in the week. It's good to get started!
