Wrestled some more with the right side wheel pant. Filed away the inside to fit around the gear leg, and opened up the bottom hole wider to allow for clearance around the tire. Still more fun to go.
Clecoes holding the halves together. Nothing yet drilled to the mounts
Inside barely clears the gear leg. More cutting is needed.
