Michael and Gayle's RV-7A
Date:  2-26-2009
Number of Hours:  6.00
Brief Description:  Fabricate cowl flap mechanism
Cut backing plates out of .063 aluminum sheet to be used to provide greater strength to the mount points for the cowl flap mechanism to the firewall. Layed-out and match-drilled the plates to the firewall. Had to stop for the day when my back began acting up from a mis-step I had a few days back while using the snow-blower to clear snow in the driveway. Was on a roll with this assembly too!!!
Nut-plates will be installed later, and also a stiffening bend will be added to the long edges.
