Michael and Gayle's RV-7A
Date:  1-31-2009
Number of Hours:  8.50
Brief Description:  Fitting the cowl
With the lines already marked on the upper cowl, it only took a few minutes to cut. Cleaned up the edges with the file, then started on fitting the lower cowl. Quite a lot of time was spent working on the cuts and filing for the lower cowl. There is more tinkering with this which I will do tomorrow. It's been a bit frustrating.
Lower cowl held up with a strap in back.  Bottom edge cut is first
Rough cuts are done, now need to tweak things some
