Michael and Gayle's RV-7A
Date:  1-4-2009
Number of Hours:  6.00
Brief Description:  Installed plexiglass and miscellaneous
Installed the rear plexiglass. Had to install it twice because the protective plastic on the inside could not be removed while sandwiched between the brace at the top. Then moved onto the canopy plexiglass -- hopefully for the last time. Preparing for creating the fiberglass molding at the front of the windscreen. Changed gears some and decided to modify the axle nuts for the Jack stand that I purchased a while back... Did the right main and will get the left main later.
Rear plexiglass installed - whoohoo!
Canopy screwed into place in prep for fiberglass at the front
Axle nut mod for jack stand
