Michael and Gayle's RV-7A
Date:  4-27-2008
Number of Hours:  4.00
Brief Description:  Miscellaneous work in fuselage
Cleaned things up from last weekend when the rear upper fuselage skins were riveted in place. Re-mounted the TruTrak Pitch Servo and safety-wired the mounting bolts. Riveted the ELT mounting strap to the base plate, then re-installed the ELT (temporarily). Did some planning around the wire runs and connections at the wing roots. Began identifying all of the remaining Final construction tasks in order to plan and prioritize what is next.
