Michael and Gayle's RV-7A
Date:  4-4-2008
Number of Hours:  3.00
Brief Description:  ELT Antenna mount
Decided to mount the ELT Antenna behind the Cabin Frame. I've seen where this spot is used by quite a few builders. Seems reasonable given there are few other choices on this airframe for this -- especially considering I want to keep it inside out of the airstream. The antenna is attached using #6 screws holding tie-wrap anchors to rivnuts in the Cabin Frame. Once the Cabin Frame is painted, I will likely use black tie-wraps to secure the antenna - a minor detail. Routing of the coaxial and cable for the remote test button on the panel are next.
Base of antenna trimmed to fit
Fastened securely with a good ground
Antenna secured to Cabin Frame
