Michael and Gayle's RV-7A
Date:  3-10-2008
Number of Hours:  6.00
Brief Description:  Dynon Remote Magnetometer mounts
Finished up the fabrication and mounts. Ended up using #6 Rivnuts compressed into the ends of aluminum tubing to be used as mounting posts for stacking the Magnetometers. Pretty pleased with the results. They are mounted to within 1/10 of a degree accuracy using a Digital level. The callout is for 1 degree accurate. Well, it may be overkill to be 1/10 of a degree accurate, but I could do so -- and I did. Note: Rivnuts were used for mounting and construction as these are not a magnetic material such as a nutplate would be. So, there's no interference with the Magnetometers in this location. Holding a wet compass near or around the units do not react whatsoever. Good to go!
6.3 degree angle on D100 tray
6.3 degree angle on Magnetometer mounts
View of posts and mounting structure.  Note the band of color at the ends of each post -- #6 Rivnut!
