Michael and Gayle's RV-7A
Date:  1-28-2008
Brief Description:  More firewall pass-thru's
Located the eyeball swivel that will pass the throttle cable through the firewall. Needed to do this so I could locate the manifold pressure unit for the EIS 4000. Need to locate this so I can later locate the large hole for the engine wire loom. ...And I need to locate that so I can later locate the terminal strip for the engine wires on the inside of the firewall. One thing leads to the next...
Eyeball swivel for throttle cable
Manifold pressure unit for EIS4000
