Michael and Gayle's RV-7A
Date:  9-6-2007
Number of Hours:  9.00
Manual Reference:  8-20
Brief Description:  Upper Fuse assembly
Spent a long day fitting and fabricating the Upper fuse assembly. Quite a bit of time was then spent on the fitting and drilling the F-771 Forward Top skin to the firewall, ribs and subpanel. Also fit and drilled the F-721C and F-721D attach angles to the panel and the F-721A deck.
Upper fuse sub-assembly (forward skin has already been fitted and removed at this point)
F-721C on the right side installed
The panel mocked up with photos of the instruments (note the EIS now above the Garmin 340)
