My first time using Polyester fiberglass resin and cloth. I used a .025 aluminum cutout taped in place to hold the tip in the proper shape. Prior to glassing, I sprayed the aluminum with a wax-based coating so the glass wouldn't stick to it.
The aluminum cutout is visible through the fiberglass while it's setting up
