Brief Description: Fitting the Vertical Stabilizer
Started working on various tasks with mounting the VS. Countersunk the rear fuselage bulkhead and riveted the tie-down bar to the bulkhead. Next, I clamped the F-781 attach plate to the forward spar of the HS. Then clamped the rear spar of the VS to the back of the F-712 bulkhead being sure to center it and set the correct height.
