Michael and Gayle's RV-7A
Date:  1-21-2007
Number of Hours:  5.00
Manual Reference:  8-13
Brief Description:  Electric flap assembly
Did quite a lot on the flap assembly today. Fabricated the F-766C plate, the F-766B angle, the F-785B attach angle, the F-766D spacer and the F-767 attach plate. Fit and riveted the F-758 bracket to the bottom of the F-766A channel and installed the required nut-plates. Riveted the F-785B attach angle to the bottom of the F-785A backrest brace. Positioned and attached the F-767 attach plate to both the F-766A channel and the F-705 bulkhead. Installed the nutplates on F-767. Attached the F-766 assembly and tested the motor and linkage with a 12V battery. Runs great! ...The first electrical test of the airplane! Pictures shortly.
