Michael and Gayle's RV-7A
Date:  11-26-2006
Manual Reference:  8-12
Brief Description:  F-750 L&R Aft Baggage Side covers
Drilled and riveted the F-750 L&R Aft Baggage Side covers to the inside of the fuselage. Note: In the manual, the next step is to install the optional step kit. It would have been better to reverse these two steps and do the step kit first. In this way, the F-750 Aft Baggage Side covers don't block bucking bar access to the rivets used on the steps. Also, I strung the rudder pedal cables (aft to forward) before riveting the F-750 L&R panels. The SB-625-7 Snap bushings have to be squeezed over the cable end first, then inserted into the bulkhead. Unless the cable end is ground down on the sides, it's not possible to insert the cable end into the snap bushing while it's in the bulkhead.
Left side F-750 Aft Baggage panel.  Note the rudder cable passing behind.
Right side F-750 Aft Baggage panel.
Right side rudder cable passing out through aft fuselage
