Michael and Gayle's RV-7A
Date:  9-30-2006
Number of Hours:  8.00
Manual Reference:  8-8, 8-9
Brief Description:  Forward fuselage - preparation
Fitted/drilled the F-7101 left and right Gear Web Attach to the F-704 bulkhead, the F-902 and the skins. Spent quite a bit of time fabricating the F796B,C and D parts. These components provide support for the fuel tank attach points (shown in the 3rd picture). It doesn't look like much, but there is quite of bit of fiddling around to gets things lined up correctly. Next will be fitting the Rudder Pedal assembly while the bottom skin is off.
F-7101 fitted on left side
F-7101 fitted on right side
F-796 parts along with fuel tank attach brackets
