Michael and Gayle's RV-7A
Date:  5-29-2006
Number of Hours:  7.00
Manual Reference:  8-2, 8-3
Brief Description:  F-705 seat back stop and miscellaneous fabrication
The 3/4 angle was fabricated for both left and right sides. The height is 1/8 inch off the top of the spar. This allows a small horizontal slot which accommodates the flange on the back of each seat. Began work on the left and right side angle supports for the tip-up canopy which provide the latch base for the canopy. The flap bearing blocks were also drilled at this time.
