Fitted plug into back of the intercom module behind the fuel tank
Removed bolts holding the fuel pumps in place. Removed, applied tread sealermand replaced the four 1/4" NPT plugs in the fuel pump module. REplaced the four bolts mountuing the fuelm pump. Started pump and checked for leaks. All OK.
