MURRAY'S WEB SITE
Spitfire Mk 26
Attempt engine start
Fitted fuel tank and made up lines. Put 20 litres of BP 98 in thank.
Attempted engine start. No success. Good fuel pressure. Removed fuel tank and checked fittings. Found one leaking at fuel drain.
Fill brake lines and bleed. Installed audio plugs and control stick.
Finalised flap rigging. Connected fuel pressure sender.
Fitted fresh are ducts and engine ductiong system.
Installed diode, (3 amp, 400 v) on AAA, BBB and CCC.
Fitted transponder coax and VHF coax.
Attached air box and air filter.
Fitted split pins on main wheels.
Spitfire mk 26 Home
Spitfire Mk 26 Home
1681
Equipment
1008
Insurance
Preparations
