Placed packer in tailwheel to make it stand vertically. It is now less than 0.5 degree from vertical. It should steer much better now.
Repalced USB power outlet to better one. Tested OK.
Tied wire and encse with 1" hose by right pedal.
Ian Bristow inspected the aircraft for minor deficiencies. Items found needing attention were: - brake cylinders are missing caps - there are no grommets in the wing ribs where the strobe wires transit - advised thsi won't need rectifying - both aileron rods are rubbing agaginst the lower skins at the limit of travel - the rear shoulder retracs should be bolted through both tangs - elevator rod ends. Need to continually check for free movement - several fuel lines in the engine bay need securing
