Brief Description: Fit packers and drill out upper forward port skin
Cut and fitted packers to go between stiffeners and skin of the upper forward port skin. Match drilled to 3/32" and 1/8" holes.
Fitted upper aft skin to starboard in order to drill out rivet holes along main spar. Match drilled 3/32" holes along each edge and ribs of lower forward starboard skin. Removed aft skin.
