Today I spent some time replumbing the connector lines between the aux and main fuel tanks. The original transfer pumps I had installed did not contain a check valve, so I bought the correct part number and prepared to change them out. Of course, the new pumps are slightly larger than the first ones I had installed. Therefore, I have to redo the lines in this very tight area (in between the tanks, through a small access hatch) Ugh.
